Potential Bucket Seat pssues
Superwoman90
  Peugeot 207
I'm planning on having a driver's side bucket seat fitted. Can anyone advise on what I need to be aware from an electrical perspective so I don't end up with warning lights coming up on the dashboard.
frayz
Get the airbag warning turned off using the “Clip” software. Your local Renault specialist will have this, maybe even a local member may have a copy they can do it for you.
Superwoman90
  Peugeot 207
Ok that's helpful. I did have this done by a fellow member when I had an aftermarket steering wheel changed. Thanks
Don
  182 & Audi A3
Are you using the normal seatbelt or a harness? As if you are planning on using the seat belt, you will probably be best to order base mounted subframe with the piece on to house the seatbelt bracket and use the bolt from donor seat to allow it to work for you. That was my experience when I put a Cobra Clubman seat in mine many years ago
Superwoman90
  Peugeot 207
Thanks for the heads up, much appreciated.
  • Like
Reactions: Don
