Power Boost Valve
Can anyone tell me why there is no fuel pressure regulator on the end of the fuel line on the clio 2 (00) 1.4i. :confused:I have engine model K7J. I want to install a power boost valve...
Thanks.
the fuel pressure regulator is part of the tank sender unit on your engine.you will also notice that the fuel rail only has a feed pipe not a return as well.the return is no longer required due to the regulator being part of the sender unit.you cant fit a pbv to your engine.
tell me about it, we had no end of fuel vapourisation problems with clio V6s running in HK.....
stupid
