Power Cable 2 Batt help... 182 (56k)
Following on from the other thread I decided it was about time I put my sub and amp in the car.
However im proper stuck and have been for the last few hours please can someone offer me some help
In return I will take photos as I go and we can put together a guide for doing this!!
Ok this is the grommet in the front passenger side footwell, found that easy peezy
http://erc.qmuc.ac.uk/cliosport/gallery/full/1108033834__IMG_2295.jpg
Looking in the engine bay I can see no way of getting to where the grommet feeds out.... Is there a simply way.
I have remover the coolant reservoir but there is lots of sound proofing
http://erc.qmuc.ac.uk/cliosport/gallery/full/1108034014__IMG_2294.jpg
I have tried forcing my hand down there but it just aint happening.
http://erc.qmuc.ac.uk/cliosport/gallery/full/1108034103__IMG_2296.jpg
Guys I am close to giving up on this any help you can offer is greatly appreciated.
  Ziel Nurburgring
Easiest to do it from the inside and push the cable through to the outside. Where you based?
  Ziel Nurburgring
And after re reading your thread, you should be able to loosen the sound proofing and get your hand down to the cable, tight fit i know but its the only way.
Im in Reading mate. This is really doing my head in lol. I have not tried pushing the cable through yet. Do you think that could be the way to go?? Then force my hand down to try and get hold of it?
Right then thats what ill have to do. Was hopeing there might be a quick tip. 1 more cuppa coffee then ill get back to work. Cheers
  Turbo'd MX-5 MK4
yeah i think so, metal coat hangers are always good (if you can get it through the grommit and then bend it
tbh you dont have to remove the coolant bottle just the PAS resevoir (it unclips) will be enough. if you get stuck im in swindon and dont mind helping you do it if you popped down the m4 at the weekend.
  Ziel Nurburgring
Yup coat hanger, screwdriver from the inside with the cable taped to it is the way to go. Bit closer to marlow/maidenhead and id have driven over to help at lunch
  Clio 1.6 16v 2003
coat hanger did it for me, really sprap the wire to the hanger
double up the hanger and wrap round, then clamp it together with pliers, you will have to pierce a hole like i did yesterday
  182 Full Fat
I have just fitted my sub and amp, i simply removed the power steering bottle (the one to the right of the coolant bottle)
Then feel down for the grommet, and push, then get the good old coat hanger from the inside, and oull it through.
Its hard but not impossible!
