POWER CABLE THROUGH BULKHEAD
  CLIO WILLIAMS #0215
where is the best place to run a power cable through the car to power an amp??? do i have to drill a hole??? or is there a hole i can feed it through??? and where is best place to take the negative to from the amp?????
  williamsclio.co.uk/forum
If your on about doing it in your williams pal,
There is a hole on the passenger side bulk head (when viewed from the engine bay) which feeds through to inside the car directly behind the glovebox. Your alarm cabling should already use it. Stick your head up and you should see it.
Negative earth: Im sure there will be a hole already drilled somewhere in the boot - Ypu could trace the wiring for the rear lights? or where the existing rear speakers earth terminates.
  CLIO WILLIAMS #0215
i cant see no way of gettin cable thru the bulk head????? do i have to drill it????
That hole isnt there on my Williams 3.
I know its there on my 1.2.. but, I did have the sub/amp fitted professionally so dunno if they drilled it? There is only the amp cable going through!
Through another hole/bung.
When I helped someone install an amp/sub into a Williams, we put it through the bung where the rear washer pipe goes!
reach rihgt up under the passenger dash, behind the fuse bx, there is a grommet, about 50mm, i will post a pic of it from the engine bay if you want dude, just cut a hole in the plastic grommet, and feed the cable throiugh
