power steering drone
coolspot007007
  Seat Leon Cupra
sounds a bit non technical but...get some form of thick plastic bag (freezer bag is ideal) take off cap to P/S resivoir cut a circle from the plastic bag slightly larger than opening. Place on top of resivoir opening then screw on cap over it. See if that helps, but its generally a feature of the car, most clio 16vs do it.
Wasnt meant to sound rude, just simply they r all noisy bloody things, u get used to it. long as it works fine ur ok
  Skoda Fabia vRS
use some Slick 50 Power Steering Fluid in it, £4.99 from any Motor World
it has additives in it which will quieten it a bit, worth doing
  clio 20v
yep mine was a right noisy bastid till i put some of that slick 50 stuff in
its a miracle cure seriously i was well impressed i jus drained the P/S tank and filled it back up with the slick 50 stuff
adi
