Power Steering fluid change
Car  Black 182 FF
Think mine needs doing as to my knowledge it's never been done and there's an occasional whine/squeak when turning right when the car goes over a bump or is leaning down on the right. I've done loads of searches but none with a definite way of doing it. IS there a best place to drain from and how much fluid do I need for a change?
Yea
open the res.
pull out filter type thing.
look inside, you will find a nipple.
Put a correct size hose on nipple.
turn car on and watch the fluid pour out, as it's doing this refill with new fluid at the same time.
it's best to have someone turn the steering wheel lock to lock when doing this.
This will replace old with new and you can stop when the clear hose fluid is a nice clear red
Whereabouts is this nipple? I cant see anything in the res at all.
bottom, it should be there.
Its the return pipe.
Feel under the res for the return and try to locate that inside the res
Is it obvious? Spent about 30 mins yesterday and just made a mess!
Not sure how much to order for this, finally going to do it. Roughly what does it take, just so I order more than enough.
