PowerFlex Anti Roll Bar Bushes!
I just fitted the Powerflex suspension bushes and it do work good :-D
But the anti-roll bar bushes with 23mm inner diameter doesn't fit! You can put them on but cannot fit well. Our anti-roll bar are 25mm think :-(
Anyone came across with the same problem?
Are you sure you didnt get the valver one ? DT sent me these by mistake...!
Check the code numbers:-
Renault clio/19 - front anti roll bar (inner mount 23mm) - CODE PFF60-202-23
THIS IS THE WRONG ONE
Should be Clio 2 (inc 172) - CODE PFF60-207-23
Strange as they are both 23mm and you say the antiroll bar is 25mm. Maybe they expect you to bodge it...
Believe or not, my 2 outer mounts (they say 23mm) is with correct part number at: PFF60-207-23. And the label say Renault Clio & 19.
But my inner 2 inner mounts is wrong (they also say 23mm). It has part number of PFF60-202-23 and also say Renault Clio & 19.
I just checked the PowerFlex site and PFF60-207-23 is correct, but strange that they repeat the same part number and put 2 outer mounts there. So, no inner mount shown on their site!! Crazy!
I got them from Ktec, got to speak to David. Jesus Cry!
