Pressure Bleeding the Brake System - what PSI??
  Mercedes SLK350
If you are using a Gunsons Eezi-Bleed, connect the adaptor to a wheel valve with about 20 psi. I'm sure that is what I used last time.
I always place the bottle in a carrier bag just incase there are any leaks or mishaps.
MRBILLYUK
  FF Jeden Osiem Dwa
Like big lee says . The eezi bleed kit recommends you use 20psi . If you want to use 10 psi it will be fine .
  Clown Car
Now if you had put a bag around the reservoir, then brake fluid would probably not have sprayed everywhere in the engine bay because you did not fit the cap on the reservoir properly.:rasp:
  Mercedes SLK350
But it was your car not mine.
If it had been my car, I would have applied pressure without the brake fluid in the bottle, (dry run so to speak) to check for leaks.
And I would have not tipped the brake fluid bottle over, most expensive fluid change ever. :rasp:
