Not sure if i'm near anyone, just worried about all this talk about needing professional spring compression tools?
182 and 172 don't need spring compressor the springs are under any load realy.I didnt use spring compressors on my 'non-cup' suspension when i did it for the 1st time lol.
It was a race to get the nut on before the damper lowered while pushing like hell lol.
Height and camber setup.DT only take 90 quid to fit and set up coilovers? what is inc in the set up?
how much should I be paying for corner weighting?
I was told this about the 182, but it would have been 10 times easier with it edde.
The springs would not go below the damper unless i raised the damper, and got the nut on in less then 3 seconds while pushing the spring down hard lol
TBH, dont know if i did it the right way but its done and is spot on.
Good, Thanks.
I got a bit of a fright when i could not do it for the first few times. Thinking i would have to put both sides suspension in again and go buy some comps.
So i take it, unless your superman you cant do the same to a non sport.
