problem with my clio.
Car  Clio. :)
236 - Positive after relay supply - Short to earth.
226 - Programming throttle limits signal detected.
137 - Motorised Throttle.
Any idea on how I can fix these or if anyone has had these problems before, if so, how did you fix it?
Appreciate any help anyone could give.
check the metal cover on the ecu (rubs through wiring), the relays/wiring in the engine bay fuse board . may need to get throttle limits reset , .
