problems with brakes
Car  none :(
when im driving and i need to brake my brakes sometimes ock and grind whats causing this, it did it in the snow and also the rain tonight, it also happened this morning on some black ice.
Could simply be a piece of gravel that found its way between your pad/disc whilst braking and has become embedded into the liner.
If you have a jetwash just try throroughly washing the brakes, otherwise only thing to do owuld be to take off each pad and manually inspect it. See if you can see any excessive scouring on one of the discs.
Just an idea but im guessing its dirt/salt/gravel thats causing it.
