pulling to the left under hard braking
Martin_172
car has been off the road for a year and just recently back on, its pulling to the left under hard braking, recently had brand new discs and pads all round, front caliper sliders cleaned and re greased, 4 brand new tyres, full suspension geometry setup and camber bolts.
still doing it after all of the above, where do i go from here, going to try a brake fluid flush as it needs it anyway but waiting on my new braded lines turning up, could it possibly be a dodgey caliper? possibly one of the rears?
  M3, Cup racer'd 182
It sounds like your right front calliper is seized, but what i can't work out is how they managed to fit new disk and pads as the piston would need to be pushed back.
Greeny.
  440i + 182
I had exactly the same problem and never got to the bottom of it, even worse with decent pads :/ My caliper was also fine, was strange. Worth looking at the bushes as above.
  225 Cup & Williams
I had this problem after having the brake fluid changed on mine. The garage didn't bleed the system right so there was still a bit of air on the drivers side caliper and under hard braking it was pulling badly to the left.
