Question about computer RAM
  E30 318iS x2
My laptop came with 2GB RAM installed. I just bought 2 2GB sticks to take it up to 4GB.
I've put them both in and in the Bios it says 4096MB installed, but it says only 3326MB is available.
Can any one explain why it is that the 'available' amount is less than the actual amount?
32bit. It can only address ~3GB. Well...it should be able to adress more IIRC, but it can't.
You need 64bit Vista for it to 'see' the entire 4096.
  182FF with cup packs
Technically it's actually 4GB, but thats in total. This includes memory space on any adaptor cards, like your video card for instance.
But, yeah, you need 64bit OS for it to "see" all of it.
DrR
  VW Golf GTD
Graphics card could be using it?
Well lack of graphics card.
  Liquid Yellow 182 FF
If your using 32bit, which most likely you are, then even though you have 4gigs, the system will only show and use about 3.5gigs Max,
It is defo a 32-bit issue. The Beast v3.epic is running 64-bit Vista and its OS can see 4096. It's a known scenario.
