Megane 2 GT 165
Ok here it goes,
One of my headlight washer jet isn't working but the hose going to it isn't blocked.
While changing my leaking washer bottle I checked how the pumps were fitted and how they should work. My guess is that my headlight washer never can have worked properly. Since it is a second hand car which I already own 2+ years, I don't have any warrenty.
First professional drawing.
This is how the windscreen washer and backwindow washer are fitted, AND WORKING.
Second drawing is how my headlight washer hoses are fitted.
Explaination about the drawing.
Red block is an rubber valve that will slide from one side to the other when the washer pump is changing rotation direction.
Blue is water flowing
My question is:
Is this fitted correctly? If so the motor of the headlight washer should change rotation direction. (then probably the red block (valve is stuck) or the motor is f**ked)
If this is not correctly fitted, how should it be fitted? Or do I have a wrong washer motor fitted to my car?
BTW my car is an Clio 2 Ph 2 as shown on the left under my name. And the professional drawings was a joke offcourse.
Thanks for reading.
My question is:
Thanks for reading.
