Clio 1.6 16v Dynamique +
Can anyone tell me roughly how long it should take to change an o/s front wheel bearing?
I have replaced both front hub bearings within 2 before, sounds like a standard time for a garage though.
All the job is> 4 wheel nuts off>30mm hub nut off>two 17mm hub to stut nuts off,split ball joint from hub.
Then that the hub off, take out circlip, press bearing out, press new one in, then reverse of the above.
balljoints before struts..
Whoa, thats a bit much in my eyes, thats just under £150 for a bearing, have you tried quotes from other garages?
i just had mine done was an hours labour plus 28 pound for the wheel bearing
2 Hours todo 1 front wheel bearing?
