Chris2007 Feb 4, 2008 #1 Are there any coilovers which will fit a 1.2 2001 and a 172 2001 onwards? cheers
Tigger Car "Navy" N17 TWO Feb 5, 2008 #2 Quick answer - no. The suspension setup is different between the non-sports and the 172/182s I think it's to do with hub or bolt spacing
F f0xy Feb 5, 2008 #3 yeah......you're 1.2 will probably be 58mm spacing on the shock/hub if its a 16v.........172's are 54mm IIRC
