Quick ET question
  Renaultsport Clio 172 Cup
Hi guys,
Quick question, will et38 fit ok on my cup? Is anyone else running these and what is it like?
I have seen some 15" track alloys I want, but just need to make sure first of all..
Yes, you'll have no problem at all.
I have a set of 15s that are ET35, and running 205/50/15 tyres I have no problems with clearance.
My Cup looks like a tractor though, standard springs/dampers and minus 117kgs means it sits up a bit so I've got loads of clearance...may be a bit tighter if you're lowered.
Cheers Mark.
It's on coilovers so I should be ok with clearence as I can just adjust :)
Have you got any pics with the 15's on? Ill have a look in your posts now..
ET43 are stock
So 16 inch alloys with ET 35 will work just OK? Had one with ET25 on trackday and they did shite to my wheel arches. :dapprove:
