Quick Q re. movement in AUX related pulleys
hi. just doing my AUX belt again after the adjustment bolt has snapped and am trying to assess the various pulleys
none are noisy to spin, but there's a little end float on the PAS pump and a little lateral play in the waterpump - should these both be solid, or does that sound OK as these go?
any experienced opinion appreciated:)
pas pump's usually have a slight movement (note i say slight)
waterpumps are usually solid, maybe a tiny tiny movement
grand, thanks for that
i might do the waterpump if it's still shrieking after this (original pump, on about 80k); is there room to pull it out against the shell, or do you have to muck about moving the engine?
seems fine, thankfully. still £50 lighter after new belt and bolt (bolt was a ridiculous £30; desperate times)
