R19 16v Inlet Manifold
Car  350z & 16v Maxi
Whats the difference, just compared them and the 19 one does not have bits to screw the injector cover onto and also no where the screw the P clips. Also just behind the throttle a pipe that comes out seems to be in a different place, is that all thats different?
Im getting it chromed on monday but dont want to if it its not the same.
well itl fit to the head, tho im not sure itl fit behind the rad, as the clio 16v manifold has about 2mm of room for it to fit behind the rad...
jimbo
The 19 16v manifold does not have the support mounts at the pulley end of the manifold meaning you can not support the alternator bracket. The air by pass inlet is also in a different position.
