When it happened on mine I got the code read so I had an idea of where to start looking and then tested each abs sensor with an oscilloscope till I found the problem.
Kwik fit used a bosche code reader and pointed to rear right abs sensor and turned out to be correct after testing.
But it could also be something such as incorrectly set up brake pedal switch.
