Radio code?
Pep
Living Dangerously
Car  M2,XJS,S1000RR
How can I find it?!
Disconnected the battery earlier and now need to put it in to work.
Have no paperwork etc.
It's an 01 ph1 172 with tape head unit and 6cd changer.
Front page of your Service book.
If not, then dealers, £10 iirc or one of Traders on hee can supply one iirc.
If you know the original dealership the car came from (and it still exists) give them a call. Pretend you're from a garage/dealer and chances are they might supply you the code. It used to work for me every time.
I just went into my local dealership and asked for it, they didn’t charge me anything. Will only work if it’s the same radio as the car left the factory with though.
If its not the original radio that came with the car then hold numbers 1 and 6 together and the pre-code will come up, Renault will then type that pre code in along with your chassis and it will give you the code for that unit.
Got a reply from Josh earlier thanks Kat, so will be sorting it as soon as I can find my removal keys!
Sorted, have emailed the code through ebay, thanks :)
