Rain Sesnor question on dynamique
Hey guys,
Just a quick question, when I move the stalk to position B (where the system detects rain presence) every time the wipers move I hear a slight clicking noise. If I select position C or D it's silent. Is this normal?
Ah, just another quick question. When you enable auto lights, is it one beep or two beeps to turn it on?
And what position do you turn the lights to for the auto feature? I've the manual and it's a little unclear.
All the way on and all the way off twice IIRC.
Only have the key in the position for starting the engine as well.
Yeah that's to enable them but does one beep mean they're enabled or disabled?
And do you leave the lights on dim for auto feature to work? I.e they'll go full when it's dark?
auto-lights are for dipped beam only. they will not activate your sidelights, then dipped.
they are either on or off.
to turn the auto-light feature on or off.... turn the light switch from position 1 to position 2, twice. you'll hear a beep
Sorry, I don't think I'm being clear enough.
In order to turn on the auto-light feature you turn the ignition on and turn the stalk knob fully up and down twice. Correct? Now you do the same procedure to turn it on and off.
My question is, how does one differentiate between the beeps?
1 beep = off or on?
2 beeps = off or on?
That's all :D
Correct! As you said... Ign on, sidelights on and off twice and it'll beep
1 beep - auto lights off
2 beeps - on
2 beeps - on
Awesome :D
Once they're on auto, do I need change the position of the stalk at all? For example on the wipers they need to be at position B in order to work automatically. Is this case with lights?
