Next on the list - would like to raise fuel pressure to circa 5 bar. Fuel rail is Jenvey item with braided lines / mocal fittings etc. Stock injectors.
Vehicle has a fuel tank without a return it seems so my belief is that an additional pump can be installed in series post OEM pump to generate the pressure required.
The secondary pump will have its own relay / fused circuit and will be run off the same ECU output for on/off. Is there anything else to consider or that I have missed? There has never seemed to be a requirement for a swirl pot on the car in question; so although this would be a good opportunity for its addition it may be over complication...
Your thoughts please...
Many thanks.
Many thanks.
