Random misfire
  Kangoo 182
ok so the scum run mobile has developed an annoying misfire! Car ( 172 ph2) starts up an idles fine, will drive fine for about 2 miles then develops a misfire on 1 or 2 cylinders! If you turn the car off and leave for an hour to cool down it starts fine again, suggestions please ?
  dan's cast offs.
eml? codes?
if not crank sensor or if it is down on two then coilpack/signal wire/ecu. you'd have to be bloody unlucky for it to be ecu.
  RB Clio 182
When i had a misfire only when the car was up to temp, it was my top inlet that wasnt nipped up tight, im guessing when it was hot it expanded causing a slightly larger air leak, nipped it up properly and it went away.
