rattle/ banging
Car  ph2 clio 172
hi not sure if u can help but i seem to have a rattle/ banging sound possibly exhaust banging , any ideas how to stop this ????? cheers;)
Might just be hitting/vibrating on the exhaust heat shield. Jack it up and follow the exhaust with your hand and see if it's really close or leaning on the shield. If it is, check the rubber mounts off loosen the 'u' clamps and twist the exhaust to see if you can increase the distance from the shield.
ok will do , thanks alot :D
