Rattle, is it fixable? (see attachment)
Basically had to take my door apart once to fit the electric window motor.
Now, the inside door pillar plastic sits a bit high, and there is a gap (as seen in the attached pic, not my car but shows the same bit)
Basically when driving that area makes a rattle. When i push down on the pillar (closing the gap between the pillar plastic and the rest of the door card) the noise goes, but after a few seconds the gap pops into existance again and the rattle returns.
All of the clips for the doorcard etc are intact... is there anyway i can force the pillar to stay in its correct position so it wont make this rattle?!!!
EDIT - dont really wanna be forced to use epoxy/superglue just incase i need to change something/open up the doorcard again
Thanks,
Ahmed
I have just used a little bit of sponge behind.
Also, if you take the trim off, you will see 2 or 3 clips and circular plastic washer type things. Basically i glued these to stop them from moving, fixed it :)
Thanks for the reply
Where did you put the sponge exactly?
Also, which clips did you glue? the ones on the plastic fascia or the ones on the metal door?
Thanks,
Ahmed
