Rattle or blow - with vid...
http://uk.youtube.com/watch?v=OyQXMjQAnOw
I know its hard to tell from a video but to me that sounds like a rattle or like something is loose inside than a blow am i correct ?
Reason i ask is before fitting when i turned the centre section around or moved it up and down i could hear something inside it like something was slightly loose but thought nothing of it...
But when fitted it doesnt sound the best IMO..
Does the rattle occur at a certain rpm ie 4000rpm? if this is the case you could have a loose baffle in the center section
Or does it increase the more you rev it? if this the case, then its either a loose heat shield or you have a leak in the exhaust. Check the joins.
can't hear a rattle but does sound as though it could be blowing a little (when you pulled away). shouldn't be anything rattling around in the boxes - as suggested, you've either a loose baffle or something in there that shouldn't be - not necessarily a big deal, mind
it only does it between 2.5 and 4k then it seems to stop...
I think somethings loose in the centre section as its deffiently not blowing :(
