Rattles in 197 doors
  Clio 1970000000
I have rattles in both of my doors. The noise comes from around where the speaker housing is and although annoying (especially from the passenger door) is not the end of the world.... It is probably such a small movement that it will be hard to sort out.
Questions:
1) Does anyone else have rattles in the same place? Before you say that it is something I have put in the door bins, its not.
2) How hard is it to take the speaker covers off? Can I take them off without unscrewing anything else? Same goes for the rear speakers please.
seb
  Clio trophy
i don't know about the fronts but the rears come off with a bit of pressure iirc using a screwdriver in a tiny little slot. they basically just slot on. you don't need to take any trim off to get the rears out.
plus there aren't any rear speakers. only the cables to fit some. the 197 as standard only came with front speakers.
  Nimbus 197
I have a rattle coming from driver's door, driver's side vent, driver's seat, driver's seatbelt thing.
A temporary fix for the door rattle is to elbow it :p
  Clio 1970000000
There are rears in mine now:cool:
  Mondeo TDCI 130
I have a ratlle in my 200 drivers door!!! Does my tits in, may investigate, sounds like a wire or something rubbing!
  Clio 1970000000
I have been listening to my rattle and reckon that if I door panel off I probably wouldn't find it as it could be something tiny causing the problem. That's why I was thinking of just taking the speaker cover off and investigating from there. If you find out that the speaker cover can come off, please let me know.
I think I will just live with it and put it down to chararcter. Considering some of the posts I have read about horror stories that others have had with their car, I really don't have anything to be unhappy about. I think my car is the nuts.
  Black 197
To get the grills off the fronts its exactly the same as the rears
Slip a screw driver under the gril of the fronts i.e end of screw driver down inside of door bucket etc, If you feel under the grill you will feel a very small slit and slip the tip of the screw driver in there and it will pop off... Theres nothing that can rattle in there though as the speakers are screwed to a plastic cage so i doubt the speaker grill is your culprit
OBTW my 197 has no rattles (yet)
  320d
I have rattles from the moment I turn the engine on to the moment I tun it off. I'd get used to it as the car gets older.
daydotz
  Clio MK4 TCE 120
funny thing my door speaker cover worked its self loose :S didnt expect it i thought they were quite sturdy
Gaz_
  Extreme mode
There are two plastic caps on the hinge sides, glue them in 100% sort it, trust me :)
