Karlos172
Clio182 Trophy/R5GTT
On the way to work on Monday literally got 1-2 miles down the road engine not upto temp had red oil warning light come on and stop so pulled over straight away and switched engine off. Re-started it and after 1-2 minutes it came back on so limped it home dipping clutch and letting it idle and switching it off again. Left it for half an hour went to re-start it, revved it a little and no warning lights. After work went back to it as had to leave it on the drive for the day, started no warning lights, oil splashing about under oil filler cap and flicking spots of oil out so drove it to work 13 miles away no higher than 2500 revs again no warning lights.
I booked it into Renault dealership just down the road from VW where I work for some diag for peace of mind thinking its the sensor/oil pressure switch. They have done all checks, pressure switch/sensor all ok, on idle oil pressure is 1 bar, at 3k rpm its 3 bar and cant find much wrong apart from an intermittant loss of pressure perhaps whilst vehicle being driven. Recommend sump removal to carry on investigation work, or for me to take it back and see how it is. They advised worse case scenario its sump off, check oil pump and possibly replace oil pump for a new one at ££££. I said ill let them know tomorrow morning, not keen to keep driving it as do the odd long run and dont wanna kill the engine or be stuck at roadside.
Its a 55 plate Trophy, 70,000 miles on the clock, near full history thats had oil and filter change when I bought it with geniuine filter and 5w 40 oil, previous owner had a garage service it just before I bought it with 5w 30 oil, genuine filter and some engine flush stuff (thats why i changed it straight away as flush/wrong grade oil not ideal). Any ideas?
