Rear bias valve...
M
mini-valver
Removed the ABS and fitted a non ABS master cylinder. This means I have 2 lines to the rear. Now, the bias valve has 1 inlet and 1 outlet meaning I'm going to have to either T the 2 rear lines from the master cylinder down to 1, into the bias valve, out of the bias valve, T again into 2 and split to each rear brake. OR block one of the outlets for a rear brake at the master cylinder and run a single line through the bias valve and T inside the car to each rear brake.
Now Im not 100% happy with either of these, nor do I really want to be using the ABS master cylinder because I'll have to T the front lines then.
Anyone have any input?
M
mini-valver
You'd never get them both identical without dropping it in a set of rollers and then you cant set it on the move accurately.
M
mini-valver
Needs to be right, or it'll proper piss me off, lol. Not keen on splitting the fronts but I think its probably the best way to go and use the ABS cylinder. Unless I can block one of the rear outlets without it having an effect on the efficiency.....
fearless
Tbh, if it was mine, I'd use the abs cylinder and T the fronts. Be similar to my old race mini then and they were spot on.
Why you removed the abs?
Couldn't you use a different master cylinder. The 205 gti has two front outlets and one rear. Don't know what the fitment would be like as I've never had a clio one off but you never know with the french.
M
mini-valver
ABS s***s itself with the 4 pots!
Gonna blank a rear outlet off I think, seen a few Fords done like it so it should be ok. Dont want to put any more joints in the front lines than I have too and I dont like the idea of running 2 4 pot calipers from 1 brake line.
Gaz_
  Extreme mode
What do the 172 cups run? Could you not use that set up?
M
mini-valver
Steve Kev was supposed to do some research ut he's even more useless than me :cool:
Gaz_
  Extreme mode
No need for the lazyness tbh, maybe he's been entertaining mrs kev?
  LY 182
not posted on here in ages! use the abs master cylinder and t the front brakes...
thats how mines done and its spot on
