Rear brake pad types?
Car  Astra SRI/ Hornet
Does any1 know which rear pads fit my 05 182cup. With or without the butterfly clip as I just went for the later butterfly type.
Cheers kev.
Ph1 172 use ones without a butterfly clip, iirc.
I'm not sure if they changed since then, though.
Front pads have the butterfly clip that presses against the caliper to keep the pads seated.
Rear ones have a metal wire that bends round to hold them in, as well as the sliding bar, iirc.
My old pad's there's no clip i think i know what you mean though is it a tiny clip??? If it is it's used when you slot the small piece of metal in to keep the pad's in place the buttery fly clip hold's that in place.
there's a small nipple on 2 of the 4 pads. It locates in the piston (have to align the piston to it) as in the pic above
