PH1 172 Sport
Set out to adjust the handbrake cable today then noticed that the inner rear pads were down to 0.5-1mm of pad! They have only been on there about 20,000 miles is this a normal amount of wear? They have been through a trackday as well.
The drivers side disk was quite worn compared to the passenger side which seems to have been caused by everything seizing up.
However the inner pad with the most wear was on the passenger side and the disk still looks brand new which is odd!!
How long should the rear pads last? They are the ferodo ones from halfords if that makes much difference!
