Rear disc spacer
Car  2003 Clio 172
Hello
Does anyone know if all Clio's with rear discs should have the little spacer behind the bearing?
I am in the middle of changing the discs and pads all round on a 53 plate 172 and it has no spacers behind the bearing. When refitting the new disc it is now catching on the ABS sensor.
Does anyone know the Renault part number for the little spacer?
Is it Renault only or can I buy online?
Only have this pic on my work computer but ye think it did on my 182.
you sure its not stuck to the old bearing?
Thanks for the picture
It definitely isn't on the old bearing, the new and old look exactly the same
I can't get through to my parts department to even check with them
I'm new to Renaults, is there a good online supplier of parts?
Recently had to buy these when replacing rear discs as mine were cracked
part number; 6000073518
£7.05 plus VAT each (from dealers)
These things were an absolute nightmare on my car earlier this year when I replaced both discs
Wondered why they wouldn't sit right and the disc/wheel wobbled when everything was tightened up again
£8 and 4 days waiting on Renault to get them in stock while the car was in mid-air holding up a mates lift - awesome craic! :banghead:
