Rear Discs
  Clio 182+ Cup pack
Whats crack with rear discs on 182? Been told the wheel bearing is held in with the rear disc or something? What they like skill wise for replacing?
Poopensharten
  Golf R
Yeah the rear bearing is actually in the disc as opposed to conventionally in the hub (don't ask).
Replacing them is a piss case if you know what you're doing with spanners - just remember and put the thrush washer (washer behind the disc) back on the right way.
  182, SQ7, Trafic
It's easier to buy new rear discs with the bearings pressed in too, Renault is your best bet, or G172 on here
mossyv6
  Trophy,V6,5GT,AG200
£90 of eBay for a pair of genuine Renault discs complete with bearing and ABS ring.
Piece of pisch to fit, but you do need a big socket (sorry cant remember what size) to undo the axle nut.
  PB Clio 172
I would avoid e bay discs if I were you
I couldn't be bothered to do it myself so took the discs to a mate of mine to fix
  Clio 182+ Cup pack
Thanks a lot everyone... What are the front ones like to change? Are they just like a regular disc fitting?
  Clio 182+ Cup pack
Sound cheers everyone... Do you guys have any idea why my steering wheel after been tracked up and straight returns to 'a few minutes to the hour or past' or 'on the ****'?
  Clio 182+ Cup pack
I've had it done at 3 different places now and its starting to get boring... Also I've just had new tyres and track rod ends fitted before the realignment.... Can anyone recommend anywhere in the south yorks area?
  master,meg, 205 maxi
i had it on a mates 182 after changing tyres (same as what was on but new) steering wheel was of to left tracking was spot on so we adjusted it to get it straight when he had the next set on it was off to the right by the same mount! strange but true???
George@RTR_Parts
ClioSport Trader
If you become a member mate you would be able to see all the Traders' sections ;)
doncaster based independant renault specialist
www.ddconline.co.uk
contact 01302 340300 lee or rich.
also find us on facebook.
