T Tez. Car Clio Sep 6, 2009 #1 noticed last night that when i brake the rear fog light on the dash does a quick flash up ONLY! on the dash THAT! im aware of :S gonna take the rear lights out later and a qiuck blastof WD on the conector block Did a search an nothing came up about this?
TheEvilGiraffe ClioSport Club Member Sep 6, 2009 #2 Mine does this .. tends to be in the wet. The actual light doesn't come on tho... French electrics FTL
Struggler ClioSport Club Member Car Ph1 track 172 Sep 6, 2009 #3 super duper common problem, its corrosion in the connection at the rear bulb holder, where the wiring block plugs into the bulb holder, clean it up, or replace it.
Struggler ClioSport Club Member Car Ph1 track 172 Sep 6, 2009 #4 http://www.cliosport.net/forum/showthread.php?t=447594&highlight=fog+light http://www.cliosport.net/forum/showthread.php?t=433449&highlight=fog+light+corrosion http://www.cliosport.net/forum/showthread.php?t=401266&highlight=fog+light+corrosion epic search fail!
Addz ClioSport Club Member Car Trophy, TVR Tamora Sep 6, 2009 #5 mine does it after a good wash and my clio before it did too, always meant to look into it!
T Tez. Car Clio Sep 7, 2009 #6 clio142 said: http://www.cliosport.net/forum/showthread.php?t=447594&highlight=fog+light http://www.cliosport.net/forum/showthread.php?t=433449&highlight=fog+light+corrosion http://www.cliosport.net/forum/showthread.php?t=401266&highlight=fog+light+corrosion epic search fail! Click to expand... ok so i did not do a good seach , ended up reading how to wire up the front fogs up with flash :clown:
