Rear lights solution!!!
Car  Clio Sport 172
Guys further to the thread I posted a while back about my rear fog light lamp lighting up on the instrument panel whilst using the brake, reverse and indicating.....I removed both cluster give them a good clean with a wire brush and a GOOD sprying with WD40...problem solved.....until it rains!!!!!
No probs at all with the lights when its fine, when it rains then I get the short/problem:mad:
Must be water/moisture getting into the lights when its raining?
Can I put any thing on the light clusters to stop the water/moisture getting at them and causing this prob....like a grease or something which will hold the water off the lights??
Is the foam seal perished? maybe its new light cluster time??
happened to me, i simply wrapped the conector block in electricians tape to help keep moisture out, worked for me give it a go perhaps
