Rear pad fitting..
Car  Nothing at the mo :(
Anyone got a guide on these? I tried to search in the guide section but it wont load after i click search :S
Just pads?
Loosen wheel bolts.
Jack rear up and put on stands (with handbrake off!).
Remove wheels.
Remove metal clips that hold pads in.
Tap slider out with hammer and screwdriver.
Remove two bolts that hold caliper yoke.
Everything will fall off.
To fit, reverse procedure.
You'll need to wind the piston back in with a flathead screwdriver though.
2 bolts to remove the rear pad carrier, pop it off, pull out the pin that holds the slider in place, tap the slider out, pads will come out, new pads in place, tap slider back in, pin back in, wind back the caliper piston with a flad blade screw driver, re fit calliper.
can be done in 10 minutes!
Also may help to take the lid off the brake reservoir, makes it a bit easier when winding the piston back in.
omg how long have you been on this forum ;) At the top of the guide section Fubar has done a few guides. One of which is brakes. If that doesnt help, then i've done one too;
http://www.cliosport.net/forum/showthread.php?394322-FubarNet-Guides
http://www.cliosport.net/forum/show...nes-and-handbrake-adjustment-on-182&highlight=
There you go flower :)
Fok ive been here a while now.. and i actually looked in fubar's bit.. must of just completely missed it lol.. cheers bud
As you will have all the brake dis-assembled don't forget to give them a good clean, wire brush and brake cleaner will help.
