rear pads and discs question
  MK2 Escort, Clio 172
Mine have worn quite thin and need replacing. Is it possible to fit new ones whilst keeping the old abs rings and bearings. Also, can you buy the abs rings and bearings separate?
Thanks in advance
  Mondeo TDCI 130
Advisable to have new bearings, the ABS rings can be re-used if they are not damaged and come off ok!
You can buy the ABS rings seperate, even though renault will probably say you can't! I used to have the part number, not sure where though.
  320d
You can get the barings seperate but its prob cheaper in the long run just to buy the genuine renault rear discs with new barings already pressed in them from GSF
They're about £150 for the pair of rear discs with barings in
Pads are less than £10 from gsfcarparts . com
  Clio 182
I think the rear discs and bearings are all one unit, could be wrong like but think they are
  320d
  Clio 182
  320d
  320d
They're about £150 for the pair of genuine rear discs with barings in
