Rear Wheel Bearing Change
Car  Clio dCi
My rear wheel bearing (Clio dCi) has given up & I'm about to change it.
I've bought a Renault bearing kit 77 01 205 812 & I see the bearing is 40mm deep. This seems like a lot of surface area to overcome if I was to try & get it out without a press.
Has anyone managed to drive a bearing out by hand or am I looking at a trip to my local engineering type guy?
Thanks.
agreed, get them pressed in and out. you need 50 tons or summet to move the sleeve LOL
local garage should only be £10
Ive managed to get a bearing out of a clio drum in my garage before by using the cave man method. Its a lot of effort and the old bearing was completly destoryed, best to take your drum or disk to a garage and get them to press it out and stick the new one in.
Yup, got the drum off yesterday & my suspicions were correct - a knackered wheel bearing. Had a go at knocking it out with a few strategically placed blows but decided in the end to get it pressed out!
Thanks for your replies!
Parts - bearing/circlip/dust cap & nut £41.52 btw
If anyone's looking at this thread in the future I can tell you I needed:
30mm socket to remove the rear hub nut. (torque to 129lb)
Circlip pliers to remove the clip securing the bearing.
Bearing kit - £41.52 (one side)
A trip to my local Renault garage to press out/in the bearing(s) - £16.45.
All sorted now!
Cheers.
