Recommend me a lens
  E30 318iS x2
I'm thinking of saving up for a wide angle lens but unsure what to go for or whats about.
I have a Canon EOS 1000D, currently have an 18-55 Canon lens and a 75-300 Tamron lens.
I have had a look at 10-22mm ones but then keep seeing fixed lenses and not sure which I'm better off getting, I definitely don't want a fish eye. I can't afford a Canon one thats a cert but just wondering if there is a good alternative (From likes likes of Tamron or Sigma?). Photography is a hobby not a profession hence why I don't want to blow the bank on one.
Would £250 - £300 tops be a reasonable budget?
Canon prime lens would be my suggestion before wide angle.... everyone needs a prime!!!
Two good choices....
EF 50mm f1.8 II (£80)
EF 35mm f2.0 (£220)
But if its wide angle you want... you could get a 2nd hand Tamron or Sigma for the top end of that budget.
Scrap that Sigma idea... the 10-20 is still way over budget even 2nd hand!
Ian
  Focus TDCi
Sigma 10-20mm can be had for around £325 I believe (the f/4-5.6 version), which is what most people will recommend. You can pick up a second hand Canon 10-22mm for a bit more than that. There's also slightly longer lenses, which are usually 17-50mm or something like that, but you won't see much of a change over the kit lens and they are outside of your budget.
Prime lenses can be had, but if you want a wide prime they tend to be quite expensive and still won't be as wide as your kit lens.
