Red induction kit hose links instead of current blue?
Car  BG182 FF
I'm looking for a red induction hose? I was given the blue force hose with breather extension which I know are about £70, but it doesn't really fit the black and red theme.... Has anybody got a link or wants to swap for a red one?
Ignore the blue cold air feed hose as I've got a longer black one on order, as that's for sale at £10... Got a lot of wear but still works.
Thanks!
Having just rebuild my engine Ive now got loads of parts spare - some I bought and didn't need, some Ive swapped for polished or painted versions so ready for someone else to do the same
All parts can be collected from Cardiff or will happily post - all prices include postage
Racing Blue / Black Engine Cover - Been professionally painted Racing Blue with a Gloss Black rear section - Its not the best quality finish in the world but looks great unless you are 2 inches away from it.
£35 including postage
Genuine Renault Clio - 3 Door (so all 172's and 182's) Roof Rack - with Fitting kit and full instructions - in mint condition, I bought it from someone on here to carry my bike but haven't used it all summer so might as well sell it on
£55 including postage
I have a load of unused spare Blue Wire and Hose covering - One pack is a full set in the 3 various sizes they come in and the other pack is 10 metres of the 7mm diameter covering - both packs come with loads of matching cable ties
Will take £12 including postage for the full set
Will take £8 including postage for the 7mm pack
Got an Alternator support bar powder coated gloss black ready for the rebuild but then decided I wanted a polished one so didn't use this
£9 posted
Having replaced all the engine hoses now for Blue Samco's I have no use for my red Forge Induction hose - is in really good condition though the one end looks like someone cut it using their teeth, just needs tidying up - works perfectly
£30 posted - will include in the induction kit pictured below for an extra £5
Managed to get a snappy Steering wheel a few weeks back so my original wheel is of no use to me now
£30 posted
Throttle Body taken from my 05 plate 182 - covered 78000 miles, have cleaned it up so ready to fit
£20 posted
Full set of perfectly working injectors - all cleaned and refitted to cleaned fuel rail
£30 delivered
RS Stamped inlet manifold - taken from my 182 - All cleaned ready to paint / fit
£35 delivered
Dogbone mount - only a couple of thousand miles of use, just upgraded to powerflex instead
£7 posted
Cam Belt Cover - removed from my 182, cleaned & ready to paint / fit
£12 posted
Power Steering Pump Mount - removed from my 182, cleaned & ready to paint / fit
£8 posted
Gear Box Mount / Battery Tray - removed from my 182, cleaned & ready to paint / fit
£12 posted
Thermostat Housing - removed from my 182, cleaned & ready to paint / fit
£12 posted
Aluminium Mount - fixes to rear of block - removed from my 182, cleaned & ready to paint / fit
£6 posted
Driver Side Aluminium Engine Mount Section - removed from my 182, cleaned & ready to paint / fit
£9 posted
Alternator Support Bars x 2 - removed from my 182, cleaned & ready to paint / fit
£12 posted
Gear Box mount - removed from my 182, cleaned & ready to paint / fit
£7 posted
Yellow Samco Hose - 13mm diameter - 95cm length - brand new - never used
£20 posted
Power Steering Reservoir Cap - Mint condition
£4 posted
Interior Heater Fans
£15 posted
Climate Control Panel - works perfectly, mint condition
£15 posted
The fact
Fancy swapping for my blue force hose? As you can see mine is out of place and I need red :L I have cut it though to make it smaller?
I have a red Smaco one that i would love to swap for a red Forge one as i have Forge hose's all over the car
