Relay Help
Car  PH2 Clio 172
So the heated rear screen on my 172 is still playing silly buggers. I bought a new switch but it didn't solve the problem where the heated rear screen comes on when I start the engine and wont turn on or off from the switch.
Next thing I want to do is replace the relay/s. Went to the Ren' dealership but they couldn't tell me which relay I needed, the parts computer only tells them the amp rating not what each relay does..... helpful.....
I figure the wiring for this should be the same as any regular 1.2 Clio et al of a similar age (mine is a 52 plate). Has anyone got a Haynes manual... can you look up the relays that work the heated rear screen system for me?
