hey guys, so as the title says i've got none of the following lights working in my Clio II 1.2 from 2004 (left hand drive), when i got the car the lights for the temp control didnt work, so i changed them.
a couple days later i run the wires for the sub, all connected just needed a headunit, i drove without one, then i realised i needed some adapters for my radio, so i just plugged the old one in to have something to listen to meanwhile. after connecting the radio i realised there was no light in the radio, the speedo, the climate control. I searched around for the problem and saw more people had the same issue, i also saw multiple say they didnt have any rear taillights, so i checked, and sure enough they we're not there.
i checked the fuses for what i believe is the light for the temp cont. and the radio, they were fine. some people said that a relay was loose, after people had sat in the passenger seat, and i actually did yesterday.
the relays were supposed to be in the passenger side (not sure if thats the left hand or right hand version) but either way i couldnt see them on neither left or right, could someone tell me where i should find those relays? or what might've else been the problem?
thanks in regards
thanks in regards
