Remove ABS lights from Dash
Coops Mk1
  Lots of Scrap...
Friend of mine has removed the ABS from his clipsort transplant thats in a mark 1 clio
the car has a bias valve so no comments about removing fuse being dangerous yada yada, the cars braking system is fine, its mark 1 spec and works perfectly, its just the mark 2 loom/ecu wants to see ABS that isnt there
as such the brake stop and handbrake light are on constantly, has anyone managed to unpick this and make it so when the ignition is on the lights go off as they should then work on the handbrake and for low brake fluid as normal??
any help/experience/advice much appreciated
cheers
Ben
