Remove old brake fluid or bleed it through?
  Impreza Wagon
I'm planning on changing my brake fluid for some ATE super blue however what's the best way to remove the old stuff? I'll be using a Gunson Eezibleed kit for reference.
  SQ5
You can't just remove and replace. Needs to be bled through. Do not let system run dry, make sure the reservoir is kept topped up.
  E46 M3
The only way is to bleed it through. You can remove a little from the master cylinder with a turkey baster if its particularly full.
  Impreza Wagon
Thanks for the quick response, it's what I thought but I read some threads that made me question it! I imagine 1ltr will also be enough for the whole system?
  Impreza Wagon
When fitting them do I have to be careful to keep fluid in the system? I read about getting air in the ABS system which sounds worrying!
