removing airbox
to fit an iduction kit you have to remove the original airbox....can any1 tell me how many screws there are and where they are roughly located...on a 2005 1.2 16v
cheers guys
nice helpfull answer ^ :rolleyes:
2005 1.2 16v is a phase 3 with new type engine, its different you cant actually see the airbox as far as i can see (not had a good look)
heres a pic of my mums to give you an idea, i assume the big black engine cover needs to come off to give access to it?
look at the throttle body there is a clip round it , undo that with a screwdriver make sure the clip is loose, then unhook the oil breather near the throttle body. you then need to pull the whole airbox off give it a hard yank and it will pull off, then pull off the cold ait feed. hook up your induction kit to the throttle body and off you go
