Before I rip off the side bump strips and replace with my sprayed ones... what's the best way to remove them? Do they unclip or have I got to slide them in a particular direction!?! :S
They both slide out. The door ones slide towards the back of the car and the smaller ones slide towards the front of the car. The small ones should slide off easy enough some times a bit of force is needed. For the door ones open the door and there is a small rubber circle behind the strip take this off and use a screwdriver or something to prise the end clip off while you slide it. Hope this helps
If you open the door, on the inside of the door is the rubber circle. just underneath the door lock. Its actually on the inside of the door not between the strip and the door.
