7R
Just get it blasted off with an impact gun.
Have you got spring compresser tools? Your need them.
Wont that just turn the spring?
Tried kwik fit...as expected they wouldn't do it
I'll ring the local garage at 9 in morning first. ..im a bit out of your way if you're in Warrington
as I said in my post above, if you get a normal socket on it with breaker bar (or even just the ratchet) try undoing it , there will be some initial give where you think you are turning the spring and then it will crack off...I have successfully done this every time I have had to remove one.
Cheers Mike. ..appreciated.
I'll let you know how it goes in the morning with the garage
I've always found you don't need spring compressors on my 172 FF, is it any different for a 182?
