That's what I need to do. I have a new gear lever and mount as I don't want to hack up my original so assumed that the centre console would need removing as well.why'd you want to remove all that ? if u just want to remove the gear stick, just unbolt it from below 4 nuts, bend the heat shield out the way, and undo the mid exhaust / cat joint and the gear stick and plastic bit wll fall out, thats what to do if u just want to remove the gear leave
