Two of the nuts are under rubber bungs and the other 2 are located around the exhaust pipe. undo all for and your seat will lift up and out. That goes for the drivers seat not to sure for the passengers.
yeh exactly the same for both seats did mine this weekend, aslong as you got a decent jock then shouldnt take too long to remove! just 4x 13mm bolts per seat!
Removed the damn offside subframe/ slider part of the seat (the broken bit), whilst I was there I removed the 15mm vibration mount thingies to get the seat slightly lower.
Now all I need to do is find a breaker yard, to replace said broken slider thing lol
I presume 172 ones aren't spethal ones lol and that all Clio Ph2 ones are the same (he hopes!)
